HELP !!!! 2001 Nissan Frontier with the 3.3 liter motor
ceojoe
Car: 2001 frontier xe 3.3 4WD
I have a 2001 Nissan frontier XE crew cab 4 wheel drive 3.3 naturally aspirated motor I have a multi cylinder misfire code P0 300 and I have changed my spark plugs, my wires, my rotary cap, my rotary button it has had a new timing belt, new fuel filter and I'm still having misfire problems and do not know where to go the distributor was put on before I purchased the truck. :gotme
macgiver
mac , could that have been one of those vehicles previously submerged , flood or hurricane , what's your locale - & vehicle history ,miles on car ,humid -salty environment ? You may have "Global bad connections '. Does any aluminum , white-metal have "pocked - marked" look of corrosion ,which would permeate the whole electrical system ? If so -post pics of eng. cmpmt. I mean ,so many newly replaced parts here ,ya know ?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Distributors do go bad sometimes.
Bumming Bob
Car: O1 frontier
I too have the 01 Frontier with a 3.3 and having the same issues I have lack of power when I get down on the accelerator I've replaced the wires the plugs the distributor the fuel filter the battery still in laking power any ideas
Bumming Bob
Car: O1 frontier
ceojoe what was yer findings
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Lean misfire could be caused by unmetered air entering the system. Check your rubber air intake hose for cracks or tears. Taht's between the MAF and the intake and could cause a very lean condition.
How do those fail, you may ask? Age, or a broken motor mount, which is relatively common in 3.3 trucks, especially those that tow or 4 wheel much. You can check motor mounts by sticking your head in the driver front fender well and having someone rev the motor. If the engine lifts much, it's likely the mount has failed, and when they go they often take that intake hose with it.
