the converted »
https://forums.nicoclub.com/the-converted-u57671.html
Wed Mar 04, 2009 7:55 pm
1. No, redtop cams shouldn't work unless you disable vvt
2. Looks damn close if it isn't perfect.
With the engine at TDC (one back from where that picture is) you should count 5.5 teeth clock wise from level with head to the timing dot on the intake and 9 teeth counter-clock wise on the exhaust. It does look close but it's hard to tell without sticking your head in there to see exactly where level is.
It sounds like your trying to set the timing without a timing light, which isn't a good idea. Get the basics done first (timing, plugs, ect) and work out from there.
