Ok here's the deal. I've search the site and found useful info about overheating and tried a few recommended things but I can't get to the root cause. I will try to break it down and give good details so there wont' be any misunderstanding.
1997 240sx94,000 milesAuto transmission
Problem:-Car overheats and coolant boils over in the reservoir tank.
-If siting and idle it takes a really long time to get to the H but it still overheats.
-If siting but rev the engine the about 3000 rpm for 4 minutes it will get to the H and overheats.
-Starting cold if I take it out for a drive it overheats in about two mins and coolant boils out of the reservoir tank.
Things I've done:
-Change radiator cap.
-Change Thermostat
-Flush coolant (car on inclined to reduce air bubbles)
Things I've notice:-Water pump seems to be ok( this might be stupid but I left the radiator cap off and then rev my engine and coolant gushed out so I'm guessing the water pump work. If it didn't it wouldn't do that right?)
-Top radiator hose is hot
-Bottom radiator hose is cool
-No milk or oily substance in coolant
-I have heater on full blast and it doesn't feel that hot eventhough car is near the H on the temp gauge possible air bubble in heater core. I think this was cause by following the FSM for flushing coolant with the "removing heater hose from petcock prior to filling'.
Do you guys have any suggestions? Could it be air bubble? I heard of burping the system but what is the best way to do that?
I've also heard but never tried boiling your thermostat and then wedging asprin in it to keep it open then fill coolant with engine running to reduce air bubbles.
Please help. There's too much information and short of tearing the whole engine and cooling system apart I'm at a lost on how to fix this.
