rasrx7 wrote:how do you check the codes on the ecu? I have similar prob in my lwb.
Rasrx7: probs to your nice set presidente'sthis is how you check all NISSAN and INFINITI OBI ECU
Without OBD IIOn G20 models, the ECU is located behind the center console. On J30, M30 and Q45 models, the ECU is located behind the RH kick panel.
If a malfunction occurs within the ECU/fuel injection system, a diagnostic trouble code may be stored in the ECU and the ‘‘Check Engine’’ lamp will blink. There is also a lamp built into the ECU which will concurrently blink. To read Code output, proceed as follows:
Turn ignition On, but do not start engine. Using a small screwdriver, turn diagnostic mode selector switch, located on side of ECU, fully clockwise. Wait two seconds, then rotate switch to full counterclockwise position. A malfunction code can be read as the long (0.6 second) blink, indicating the first digit of a two digit number and the short (0.3 second) blink, indicating the second digit. Ensure that the diagnostic switch is to the full counterclockwise position whenever the vehicle is in use
Clearing CodesIf using a scan tool, follow tool manufacturer’s instructions to clear Codes.
A second, though more time consuming method of clearing Codes involves using a small screwdriver to turn the diagnostic mode selector switch, located on the side of the ECM/ECU, fully clockwise. After waiting two seconds, rotate the switch to the full counterclockwise position. The diagnosis will end and memory will then be cleared.
11 Crank Angle Sensor 12 Mass Air Flow Sensor 13 ECT Sensor 14 Vehicle Speed Sensor 16 TCS Signal 21 Ignition Signal Circuit 25 Idle Air Control Valve 22 Fuel Pump Control 31 ECM 32 EGR Function 33 Heated Oxygen Sensor 34 Knock Sensor 35 EGR Temperature Sensor (RH) 41 Intake Air Temperature Sensor 42 Fuel Pump Sensor 43 Throttle Position Sensor 45 Injector Leak 46 Secondary Throttle Sensor 51 Injector Analysis 53 EGR Temperature Sensor (LH) 54 Signal Circuit From A/T Control Unit To ECM 65-71 Single Cylinder Or Multiple Cylinder Misfire 72 Three Way catalyst Function 76 Fuel Injection System Function 77 Rear Heated Oxygen Sensor 82 Crankshaft Position Sensor 84 A/T Diagnosis Communication Line 91 Front Heated Oxygen Sensor Heater 103 Park/Neutral Position Switch 105 EGR & Canister Control Solenoid
