goody94q45 wrote:
I'm not sure which pulley bolt this one is but it's threaded backwards and has a special head to capture it to the bracket. No Ace Hardware for this part. Definately a stealership or salvage yard part.
Thanks for the info everyone, (the pic was VERY helpful) looks like it may be down for the count until I can get the part from the "stealership". as far as removing the rest of the fragment of the bolt that is left I think I'm going to try to remove it with vice grips or something.
I just got the car, it's kinda rough and rusty but it runs. Doesn't seem to have the famous injector issues. It does have an odd sound when being driven that's coming from the rear of the car. Sounds like a biplane is following me at any speed above 30mph, no vibration or anything just the annoying noise. I'm assuming it's the rearend since the TCS and SLIP lights are both on on the dash and you can't engage the TCS?
Again thanks so much for the helpful info, I'm not a mechanic and don't pretend to be; I'm just a tinkerer that can usually put something back together that I have taken apart.
