Help!!!! 1990Q sudden transmission problem
JDM90Q45
Car: 1990 Infiniti Q45
Recently my 1990 Q45 WHICH RUNS 100% NO CHECK ENGINE after extensive repairs and complete harness connector cleaning started slipping in all gears after stop. Seems like when I stop at a light and go to takeoff the transmission locks into nuetral and wont respond to shifting in an gear except park. When I shut it off and restart all gears engaged but after deccelerating same slipping no drive force almost like its stuck in neutral? I love this car and have spent countless hours and money to restore, I have had 2 J30s with all of miles and never had a problem. Anyone have an ideas besides a swap? Could this be a TCU problem? Fluid is clean and always added. Lucas treatment. When changed. Please help if you can, thanks.
Q451990
Were the "extensive repairs and connector cleaning" before or after the problem started?
I would run the transmission self check in the Factory Service Manual - http://www.nicoclub.com/FSM/ - and see if you get any results from that. If there's an electrical issue it should point you in the right direction. TCU failure is very rare - in fact I don't think I've heard of it ever happening. How many miles are on your transmission? From what I can tell the typical transmission failure starts with it not wanting to go into R or back into D after being in R.
Good luck!
Heath
JDM90Q45
I fell in love with the car I bought it after it was sitting for a year. I ran codes and diagnostic w and found bad injectors, and several codes to sensors due to bad connections apparantly. Fixed it and drove it for 3 days no issues no lights I thought it was a strong transmission it shifted perfectly under normal and better under heavy gas at highway speed. I qs very surprised by the power! Day 3 I was at a red light and I went to leave and it as like it was in neutral no gears worked except park. I shut it off and restarted and it went nto gear fine and took off no slip. This happened. 4-5 times and then I parked it . It's a 90 with 201,000 miles...I've been poking around seen the cooler for transmission is weak and it was 98 degrees for two days I was driving the car. The AC ran perfectly and everything was good and next day busted. IDK
