Help - 1989 240sx Fuse Problem
Accurit
Car: GC8-01, NPS50-09, GD-07
My guess is someone attempted their own lazy eye switches(two switches on the radio bezel) They dont work any more so i am trying to fix it back to stock, I am not very good with electrical stuff so if anyone got some ideas how to fix this please let me know. A good website to order the fuses from?
Pics of it stock would help me a lot =]
rocksteady_racer
Car: 90 240sx Hatchback (Manual - boosted soon KA24e)
Give me like 5 seconds, I gotta go finish my car anyway and I'll get you a pic, I think it's just two relays, so you probably just gotta go two nissan relays and swap out those contraption wires for that.
rocksteady_racer
Here you go. These pics are from my 1990 240sx, should be the same as yours. My 1991 box is a little different. I don't know what he did there. Looks like he patched in a second set of wires to control the headlights, because on my box that's for:IGN COIL/FL 30A ANTI-SKID (which I assume means it's just for anti-skid cause I don't have a relay in that spot and don't have ABS) as you can see in this pic:
unless that's just a direct wire ignition mod but that's illogical unless there's another relay somewhere.
Here's inside the fuse box:
Accurit
Thanks man, helps alot...Yeah he took the head light relay and just opened it up so he would access the controls manually with some switches to do his own lazy eye.....took apart all of it and found the motor retract fuse blown. Ordered it and just waiting on it to come in at nissan =]
Thanks again for the pics!!
