whitediamond642 »
https://forums.nicoclub.com/whitediamond642-u88918.html
Sun Oct 16, 2011 9:05 pm
I have a 2007 M35x with 35k on it. Here's the scenario:
I disconnected the negative battery cable to replace a headlight bulb. I ended up taking the cable off several times because it turned out to be the ballast and not the bulb, but I removed both headlights to test and be sure before ordering.
Basically, the negative battery cable was off for almost a week while I got the bulb vs ballast issue figured out. I got the car put back together and made sure everything was properly plugged back in and now the thing is in "limp mode", or so I think.
It starts just fine and idles fine. When driving it starts out like nothing is wrong, but as soon as I give it more than ~10% throttle it falls on its face. It's like the throttle plate is only opening so far. It's acceleration is so slow I feel it's dangerous to drive, especially on the highway.
I drove it a little bit on the side roads to get a code to show up. The only one that finally did show was the P0603 Powertrain Control Module (Keep Alive Memory) code. Nothing else.
I cleared the code and tried the ECU reset procedure (the CEL blinked like stated in the directions, so I think I got it). Same driving results. I then tried removing the positive battery cable and discharging the remaining current by holding down the brake pedal. Reattached the cable and same driving result.
I called Infiniti, but they only told me to disconnect the battery. Beyond that, they wanted me to bring it in (20 miles is a long trip in the car's current state).
Does anyone have any ideas? The only other thing I can think of is perhaps trying the Throttle Relearn (name?) procedure, but I just wondered if anyone else has had this issue.
I appreciate any advice anyone can provide.
Thanks.
