i have been having the same problem in the past month with my 07. i top it off with gas and the fuel only reads 3/4 of the way full. i have no ryme or reason for this.quietkilla6 wrote:i was driving on the high way the other day when all of a sudden my fuel (POD? CLUSTER? gauge?) started reading that i was getting 0.4 miles per gallon... then i went and filled my tank and it only read that i filled it up 3/4 of the way when i most definitly topped off... and now that this is happening it seems like im useing fuel faster but i might be assuming that because i cant see my first 1/4 of my tank... ANYONE have this happen before? REASON?
Do you shut the car off while it's refueling?504 350z wrote: i have been having the same problem in the past month with my 07. i top it off with gas and the fuel only reads 3/4 of the way full. i have no ryme or reason for this.
Did you modify anything with the exhaust or computer right before this happened?quietkilla6 wrote:i was driving on the high way the other day when all of a sudden my fuel (POD? CLUSTER? gauge?) started reading that i was getting 0.4 miles per gallon... then i went and filled my tank and it only read that i filled it up 3/4 of the way when i most definitly topped off... and now that this is happening it seems like im useing fuel faster but i might be assuming that because i cant see my first 1/4 of my tank... ANYONE have this happen before? REASON?
Wait, what does this do exactly? If they weren't connected in the first place why would you connect them?simplewon wrote:Locate the charcol canister, it's to the right(passenger side) of the stock muffler. It has a heat shield covering it. Held by three screws. Quarter inch rachet, extention and universal swivel is helpful. There are three hoses connected to the canister, one from the vent on top of the tank, one to outside air, ends just behind the rear differential and the last one goes to the intake manifold. Just disconnect the one from the tank, has strong fuel odor, and disconnect the vent that vents to outside air that ends near the rear differential and connect the two hoses together.
Power the the canister solenoid and the vapor solenoid with a switch under the dash, wire them with a large diode(allows flow of electrons in one direction) from radio shack so the computer doesn't detect a short during self test at start up.NomisST wrote:What do you mean by Bypass? Is this a simple fix or something? Please let me know more!
