Help~ 02 Q45 Bose system
Post all your Nissan electronics, car audio and stereo questions here!
Foler
I just finished putting 2x 12W6's into my 2002 Infiniti Q45. Problem is it always sounds out of phase and crappy! I have my RCA converter hooked up to where the stock sub wires (took stock sub out). I had no idea what the problem was until I was informed that Bose's internal circuitry rolls off at a certain frequencies and you actually get no more bass when you turn the system up. Is there any way to fix this?
PoorManQ45
JL Cleansweep will remove the equalization from the OEM system.
Other then that the only thing to do is remove the stock system
