loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Jan 04, 2010 5:28 pm
It's difficult to have 100% solution as various cars may show similar symptoms but the root cause may be different. Your best bet is to have the car scanned if the CEL is ON or find 'ghost codes' even if the CEL is OFF. A dirty MAF sensor/connector, low fuel pressure (due to dirty filter/failing pump/ FFR-Fuel Pressure Regulator), or poor grounding of the main engine harness may not turn on the CEL.
One has to do fault isolation, starting with the easiest/cheapest step towards the most complicated/expensive resolution. Check for the obvious problems - loose electrical connectors/tubes/hoses.etc. Make sure the battery connections are CLEAN & TIGHT. Make sure the battery is good (>12.5VDC, engine off and with alternator charging, >13.8VDC (spec is 14.1-14.7 VDC)). A failing alternator can cause all sort of problems.
Verify all intake components are clean - air filter, MAF sensor/connector and throttle body. Check for vacuum leak. Remove and clean the main harness grounding points (top of engine besides intake plenum near cylinder #2). there could be a loose connection in the engine harness so wiggling it with the engine running may expose the problem. A good dose of Fuel System Cleaner (Red Line SI-1 @ $7 pr BG44K @ $18) can clean fuel injectors and other engine components.
If the above actions did not fix the problem, clean the IACV Idle Air Control Valve) and EGR valve and tubings and verify operations. Check the fuel pressure (34 PSI with engine running; 43 PSI with Ignition ON, engine ON, auto off in @ 5 secs). One need to SAFELY connect a T-fitting to a fuel pressure gauge between fuel filter and fuel rail/FFR. Make sure the fuel line is empty before breaking it - FIRE HAZARD. Pull the Fuel Pump fuse (driver side Fuse Box inside cabin) while the engine is running until it dies. Crank a couple of time to ensure line is empty.
If problem persisted, then resistance/voltage measurements of sensors and electrical components and additional diagnostics equipment may be required.
For the cost of a single Benjamin Franklin, most common car problems can be fixed - OBD II scanner, multimeter, Fuel Pressure kit, zero-residue contact cleaner or CRC MAF Sensor Cleaner, Dielectric Grease (Permatex and the likes), Carburetor Cleaner + 10 & 12 mm sockets and ratchet drive, common blade and Philips screw drivers. No need to buy fancy scanner or multimeter for as long as they are functional. Harbor Freight and on-line stores provide cheaper alternatives to Sears and the likes - maybe even from garage sale.
