lilfetus2k5 wrote:SO I BOUGHT A BRAND NEW STOCK T25 AND PUT IT ON CAUSE I FIGURED STOCK WASTEGATE, STOCK TURBO STOCK FUEL AND EVERYTHING I SHOULD BE RUNNING JUST FINE.. BUT NO! SAME DAMN THING. ANYWHERE FROM 10-14 PSI. I RAN ALLLLLL NEW VACCUM LINES EVERYWHERE AND TRIED 2 DIFFERNT BOOST GAUGES AND IM IN THE EXACT SAME BOAT AS I WAS WITH THE T28... WHAT THE HELLLLL DO I DO NEXT?! ANYTHING HELPS GUYS! THANKS
1. your actuator hose could be too long, remember the stock one comes from the hotpipe which is located right next to the turbo.
2. your actuator hose could be too small, or clogged (i know you said you replaced it, but check it again)
3. for your actuator, you want to git signal from your charge piping
4. if all else fails, maybe to much flow? not enough back pressure?
wtf, i cant get my car to boost 6psi !(stock setup, no leaks)
