hellp with my ka-t
stanza34
Car: 1993 240sx ka24det /1996 g20/2003 g35 sedan
hi i just finished putting my kat together and it starts and idles fine but when i open or close the throttle to fast it dies my ka is a 93 but i used a 96 upper intake would this be causing the problem or could it just be a vacuum leak
adoboboy
Car: s14
What's your setup? what are you using for engine management?Is your maf pluged in and at least 12" away from the turbo?
stanza34
im using 550cc injectors z32 maf and it is 12'' away and i got a ecu retune from redline for the set up
stanza34
i did a leak test ther was none i think its my tps i replaced my old one and tryed to set it with my maltimeter i thought i had it but it still seams to be the problem what setting on the maltimeter should i be testing it on and does a 96 have a difrent tps.
stanza34
could someone tell me if im doing this right
mixeds14
Car: 240
dude im no expert, but if ur running an aptmospheric bov it can cause it to stall or die when dec.
