Hello, what happened?
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
zendog
Car: L320
I am registering as a new user but I was a member of this board before it was in this format and I couldn't log on with my old password and my old post are gone it seems. I have an L320 pickup and well, how are things around here?
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Welcome back Zendog!
phlebmaster
Let me try something....... Look familiar??
1964 Datsun L320, brake parts Here are some part numbers and pics i found on rockauto.com 521 front wheel cylinder, Beck/Arnley #0721936 521 rear wheel cylinder, Beck/Arnley #0722561 521 master cylinder, Beck/Arnley #0722660 521 rear brake line, Beck/Arnley #0730259 521 front brake line, Beck/Arnley #0731188 521 front brake line, Dorman #H36737 ( half the cost of Beck/Arnley ) 520 rear brake hardware kit, Dorman #HW17219 520 frnt brake hardware kit, Dorman #HW17200 520 rear brake shoes, Beck/Arnley #0810168 520 front brake shoes, Beck/Arnley #0810150 520 rear drum, Beck/Arnley #0830307 (wholesaler closeout-13 left when I ordered)
520 front drum, Beck/Arnley #0800307 (no picture, but it looks very similar to rear)
620 master cylinder, Beck/Arnley #0722678 ( The PO installed new 521 master so I decided to buy this master to see if i could get a dual master, looked similar in pictures so i will keep my fingers crossed)
phlebmaster
Heres the rest of your brake job.... Nice info BTW
1964 L320, tear down, part 1 Well I got the parts today, at least most of them, and during the week I started taking apart the brakes, here are some pics.... above is the right rear
above is the inside, I don't know if you can tell but the backing plate on this wheel is different than the rest. This wheel looks super clean, drum looks new.
The same wheel, the drum came off easy, after i loosened the adjuster. Could I be so lucky...........
left rear....NO! No such luck! look at this greasy mess, i might need to order oil seals! or maybe PO squirted some oil in here, or maybe it is brake fluid. What a mess? Hard to loosen adjuster and in my frustration got me first official knuckle whap while working on the datsun. OUCH!
nother pic of left rear, this drum must be made right, it was very tight on hub
nother pic, featuring improvised brake adjusting tool and super-fine general purpose adjusting device (hammer)
on to the left front, hard to adjust, tight on hub as well, had 1 locking/locating screw installed
front wheels very dirty, shoes chewed up
The tires are to large, they were rubbing all over, who the "f" would drive there truck/car like this?
front right, hard as well, but getting the hang of it now, both locating/locking screws in this wheel
more rubbing
more slime, can you see the shoes and how chewed up they are?
sidebar: the rims are 15" rims and have huge tires, the original caps held on by three pan head screws screwed in place of the original style hubcap nubs on original rims
maybe you can see in this pic Well that is all, i have new pics but can't down load from cam at home right now so maybe tomorrow Thw next step is to dismantle brakes and hubs, clean them, check seals, ect......you'll see
Vega$320, Yeah, i wondered about the fact that all four wheels have same size drums, plus I am no brake wiz but the front brakes are the oddest design i have ever seen on a car with self equalizing brakes, the rear looks like what i am used to, i imagin the fronts don't work to well if the adjuster doesn't slide freely in the backing plate. Looks like the piston pushes one way and just kind of jambs the shoes up against itself as they go around the drum.
I think i have a couple unused P-valves in my hot-rod stuff.
phlebmaster
That is a ton of work...so if you see another post you would like re posted in this list please let me know.
Search My Account Members Calendar Help Home Search by username
Logged in as phlebmaster - No new messages [Logout] <---Datsun Pickup Lovers! ---> > zenndog
Posts by zenndog Profile Topics Posts 38 posts Showing posts 1-38 of 38 Restorations and other Stories > L-16 swap (10 replies - 792 views)
Does anyone know where to get a rebuilt J15 motor? - have contacted a couple forklift companies but they never call back! Jefe/nick- do yo want ... Fri Jun 27th, 2008 03:39 pm
Common Parts > Carb kit? (4 replies - 293 views)
I stop a carburator shop here in the north san fernando valley ( los angeles ) and I was driving my 320. - asked him ... Fri Jun 27th, 2008 03:23 pm
Common Parts > E1 parts interchangability (5 replies - 316 views)
I assumed that but asked on the outside hope that it might just be the same casting style with plates bolted on to accomodate ... Wed Jun 4th, 2008 08:49 pm
here is another link I found recently http://remanufactured.com/Nissan_Engines.htm question? can the fwd E15 listed on the link above for 82-84 sentras be used in an L320? there ... Tue Jun 3rd, 2008 09:47 pm
320 Advice > Seat Belts (14 replies - 474 views)
Hey, Somehow i posted twice, can the admin delete one of the postings? Yeah it tends to be one of those simple tasks that make ... Sun Jun 1st, 2008 06:36 pm
Tulsadatsun, The bolts do not go all the way through the cab. There is a piece of sheetmetal which is part of the cab that ... Sat May 31st, 2008 01:33 pm
320 Parts For Sale > 320 rubber parts to be produced (10 replies - 359 views)
How about the rubber boots that cover up the brake adjusters? Are those available somewhere? Those would service 320, 520, 521, and even 620 drum ... Sat May 31st, 2008 12:24 am
my L320 came with 3 point seatbelts, nissan logo no less, I will take some pics tomorrow and post them. http://i301.photobucket.com/al...6.jpg http://i301.photobucket.com/al...3.jpg you can kind of see the ... Sat May 31st, 2008 12:14 am
Old Datsun Pickup lovers > 1964 L320 pick up (15 replies - 567 views)
I have been driving it for about two weeks now. I love it. Collecting parts now to redo the king pins, they are loose. I had to rebuild ... Wed May 28th, 2008 07:38 pm
Warming up for the drive into work, http://i301.photobucket.com/al...5.jpg http://i301.photobucket.com/al...6.jpg Just thought I would throw up a couple current pics, I think most of the pics above are still ... Wed May 28th, 2008 06:06 am
I have no idea if the pad is original, I just went out to look at it and I think it was not, I think ... Mon May 26th, 2008 05:11 pm
http://i301.photobucket.com/al...5.jpg ... Mon May 26th, 2008 09:03 am
Restorations and other Stories > rear axle disassembly/reassembly (8 replies - 181 views)
There is a reason for the clean pants. The night I was reassembling the axle I was pretty exited to finally have all parts collected ... Sun May 18th, 2008 08:05 am
1964 L320 rear axle reassembly 1. After removeing the bad bearing race i was ready to re-install the new one, unfortunatly i took no pictures. I ... Sat May 17th, 2008 11:57 pm
320 Advice > Sticking rear brakes and stubborn drums (7 replies - 193 views)
I really had to whack mine to remove the rear drums, I rotated the drum between strikes. Odds are if they are stuck they ... Tue May 13th, 2008 07:20 pm
Restorations and other Stories > 1964 L320, window handle replace (0 replies - 115 views)
1964 L320, changing a window handle Most of you probably don't need to see this but I thought it would make a neat little thread http://i301.photobucket.com/al...3.jpg ... Sat May 10th, 2008 09:32 pm
Photo Album > 1964 L320/2003 UD (0 replies - 396 views)
Here is an interesting contrast, my 1964 l320 on its madien voyage to work where it meets up with my UD 1800 cs bobtail http://i301.photobucket.com/al...2.jpg ... Sat May 10th, 2008 06:20 pm
here is something i found on ebay http://cgi.ebay.ca/Nissan-Dats...l1262 here is another link http://www.forkliftpartssupply....html ... Tue May 6th, 2008 07:42 am
Restorations and other Stories > NL tail light repair (7 replies - 268 views)
I hear ya, http://i301.photobucket.com/al...4.jpg everyone always tells me to put two taillights on my truck but I just like it the way it has always been, hand ... Tue May 6th, 2008 01:04 am
520 Parts Pages Links > 520 Parts links (11 replies - 1761 views)
here is a link I found, I am thinking of ordering an adjuster from him for my L320 but thought you 520/521 guys might like ... Mon May 5th, 2008 08:40 pm
320 Advice > Pertronix in an NL320? (7 replies - 380 views)
What models are listed? ... Mon May 5th, 2008 07:59 pm
here is a link i found, I am shure you guys know alot of this and probably know this site but here it is anyways. http://www.postdiluvian.org/~m....html hope ... Mon May 5th, 2008 07:57 pm
Mklotz, first off, I love the posts you have been doing , very organized and great pics. I was wondering why don't you put a ... Sun May 4th, 2008 12:13 pm
yeah vega$, since the last time someone worked on the passenger side they left off the spacer that goes under the bearing off, i ... Sat May 3rd, 2008 06:38 pm
1964 L320, rear axle disassembly, bearing removal I am not very satisfied with this post but I think it still has some usful stuff in it. exerpt ... Fri May 2nd, 2008 08:48 am
Restorations and other Stories > 1964 L320 brake overhaul (13 replies - 464 views)
1964 320, brake tear down, part 2 Boy do i need some of those brake shoe pliers, but I make due one more time ... Wed Apr 30th, 2008 08:00 am
Yeah:?, Thanks vega$, you are totally right, i just finally recieved the seals and was out checking out parts, the outer seals for the rear ... Thu Apr 24th, 2008 11:27 pm
1964 320, Extra parts update Here is the next round, I will start with a few extra parts I ordered http://i301.photobucket.com/al...9.jpg 520/521 ... Wed Apr 23rd, 2008 12:00 am
Hey you all, can you guys take a look at my motor, I think is not the original motor http://i301.photobucket.com/al...8.jpg another pic http://i301.photobucket.com/al...2.jpg another pic http://i301.photobucket.com/al...3.jpg I am almost positive it ... Fri Apr 18th, 2008 11:20 pm
1964 L320, tear down, part 1 Well I got the parts today, at least most of them, and during the week I started taking ... Fri Apr 18th, 2008 11:05 pm
Hey Mklotz70, I compliment you on your memory, you are right on. The holes on the 620 dual master are centered on around 2.350" ( ... Fri Apr 18th, 2008 08:44 pm
1964 Datsun L320, brake parts Here are some part numbers and pics i found on rockauto.com http://i301.photobucket.com/al...6.jpg 521 front wheel cylinder, Beck/Arnley #0721936 http://i301.photobucket.com/al...1.jpg 521 rear ... Fri Apr 18th, 2008 12:39 pm
more pictures http://i301.photobucket.com/al...1.jpg http://i301.photobucket.com/al...2.jpg http://i301.photobucket.com/al...3.jpg http://i301.photobucket.com/al...3.jpg ... Wed Apr 16th, 2008 09:41 pm
IMH, Yeah, that was it and it does have a sunroof which is kind of a bummer, although it seems to be installed well, I ... Wed Apr 16th, 2008 08:45 pm
320 Parts Links > Parts Links (30 replies - 2838 views)
here is a company i have used in the past for parts, specificaly amc suspension parts and a wiper motor for my 1960 bel air ... Sun Apr 13th, 2008 12:11 am
Well it is late and the wife and kids are asleep, i broke out the Laphroaig and started to ead more and more of all ... Fri Apr 11th, 2008 11:58 pm
Old Datsun Pickup lovers > Picture wanted (46 replies - 2435 views)
here my L320,bought it online, first time i have ever done that, picking it up tomorrow, can't wait ... Fri Apr 11th, 2008 11:38 pm
320 Advice > VALVE LIFTER ADJUSTMENT (5 replies - 514 views)
where can we down load the service manual?zenon ... Fri Apr 11th, 2008 11:33 pm
zendog
Car: L320
Cool!! i will look over the list and see. What happened, last year there were some folks who were going to make turn signal lenses and wind wing rubber, did that ever happen? where is kenbagby? Been a strange year.
I should be around again now. The L320 is running. I drive it still on a regular basis, I think I might need to try getting the head rebuilt and hope that the bottom end holds, the truck has a major oil leak and the valve stems definatly leak. But it starts and goes so......
I get alot of attention out in town, Datsun, the peoples car man. It is approachable.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
How big was ODPL before nico? Where are any write-up's or stickies? Is it archived somewhere I can search?
breadbox
89 Koop
84 720 4x4KC
Also you should put the amazing above posted write-up and make a Forum for write-ups on installs and repairs.
zendog
Car: L320
Breadbox-I would love to answer you but I have no idea, aparently, since that post was one that I posted last year they still have the posts saved but why they took them down and why the site went to this nico format I have no idea. It looks like the posts were saved so I will see if I can remember which of mine were good and ask phleb to repost them.
Is the post by kenbagby about the clutch shop in the midwest still around?
Does anyone have info on the front turn signal repros for the 64 L320?
Did the windwing rubber ever happen?
How about a rolecall/reintroduction?
Zenndog(now zendog), L320, joined the original odpl last year. I guess this is the original but it seems hard to search.
phlebmaster
I looked and didn't see where there was a definitive answere...you might want to send Ken and email.
Return to “Datsun Chat”
