warvin240 wrote:i tired to start it today and i had to tap on the fuel pump fuse to be able to hear the fuel pump no i know it's not the fuel pump do u think it might be a bad connection because before i wasn't hearing the fuel bump turn on at all
if thats the case then go ahead and check your fuel filters. try blowing thru one side and see if anything comes out the other side.
I would start by replacing fuel filters. and have you ever had fuel injector issues?
possible that your fuel rail or fuel injectors could be the problem...
