Welcome to NICO!
Enjoy your stay.
ckau967 wrote:What is the procedure for removing the interior panel to access the speaker?
1. Pull/slide armrest away from the door (towards the rear, away from the door hinges)
2.Remove screws and gently pop the panel loose from the door.
3.BackDoors have hidden screws behind ashtray assemblies(sp?).
ckau967 wrote:2. what the trick for getting the rear seat back removed?
Accessing the rear strut towers is done through the trunk, on either side of the fuel tank.
Rear seat removal requires folding down the center armrest and popping the slip cover loose to gain access to 4 screws.
There are also 2 screws, (and 2 bolts, one for each shoulder harness), behind the bottom half of the rear seat.
Bottom half of the rear seat should have pull tabs, that once 'pulled" you simply pull upward on the seat.
ckau967 wrote:3 The car has a drivetrain vibration between 2250 and 2400 rpm.
Not sure on this one myself. Only vibration I've ever had was speed related, not rpm. (The steel "belts" were coming undone on front right tire, rack bushing on passenger side was excessively worn and driver side had disintegrated.)
