Hello! New Sr swap, drivetrain problems...
S14BEAST808
Car: 1996 Nissan 240sx
S13 SR20DET
Megan Manifold, T25, Diff SS Lines, Greedy DP, 2.5" Megan Exhaust, Mishimoto Rad, Altima Fans, Miata Battery, CX Racing FMIC, Synapse BOV,
S13 sr20det
One piece drive shaft.
When my car is in the air lifted and when I put load on the rear end i get a god awful noise. Right around the end of the transmission and the driveshaft. I installed rear subframe collars since my bushing were bad. Good transmission mount and engine mounts.
When driving tho, car dives great and I have no noises or issues.
When the punk a** loser douche that lied to me who sold me the car years ago lol, he told me someone or himself installed an OEM vlsd. Before when I was auto ka, I swear I had two tires spinning occasionally when burning out, as in two fat skid marks lol. When I have the rear in the air, and I spin one tire, the other spins the opposite way. No vlsd right? See I bought a one piece d/s non abs open diff. My diff cover is also pretty leaky... Haven't tried to look at that yet. Any ideas you guys?
Flywheel was resurfaced and I put a used meaty exedy clutch in, shifts fine to me lol. Also new tob which is already whining.
A couple weeks ago after sampling a few turns, my transmission started to make this knocking noise as I climed rpms. It went away a couple days later tho? Haha idk..
I noticed my input shaft slightly wiggeled before I mounted the trans too...
S14BEAST808
S13 SR20DET
S14BEAST808
S13 SR20DET
Pleased someone any advice? I'm desperate.. :ohno:
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
did you check the driveshaft for any excessive front to rear and up and down movement. Also are your u joints tight? Probably need to send a buddy up in the air with it while you go underneath to narrow down the problem.
S14BEAST808
S13 SR20DET
Yeah, i had the rear in the air with my gf engaging the clutch. with the car off, i tried wiggeling the driveshaft myself. No play. Where are the u joints?
S14BEAST808
S13 SR20DET
Ok i need so good answers guy.
When i first purchased the car back a while ago, the punk told me he put a vlsd inside. As the years went down, from time to time i swear i had two tires smokin fat at some times.
Here i am now, 5 speed, sr20. Loving the power.
transmission info, new resurfaced flywheel (stock), exedy stage 2 (used) had plenty meat. I was told the TOB was new, LOOKED new, but already is noisy.
I have a one piece driveshaft from driveshaftshop. (non abs/open diff)
i had worn out subframe bushings, so slapped on some collars, and damn thats the best upgrade yet lol.
Problemmm
When i have the rear end in the air and put load on the rear (clutch pushing in and out) i get this very awful noise at the end of the trans and driveshaft like its just f*** animal.
To install the shaft i had to remove the cross member, lower trans, slip d/s in and install the other end on the diff and jack up the trans and install the memeber. I called the d/s shop and they said that normal and have heard of it before... Any ideas?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Kind of hard to get a good idea of what noise you're talking about. Can you take a video with some sound? That would help. Most normal problems would sound either like a whine or a series of clunk/thuds.
CSUPUEBLOTIM
Run the car in gear in the air and see if you can track the noise then.
SR20 311
Car: 1970 Datsun Roadster
