dyfedd91w »
https://forums.nicoclub.com/dyfedd91w-u69846.html
Wed Oct 31, 2007 7:55 am
My problem all began with a crappy idle. I checked out vacum leaks, timing, plugs, 3 different mafs etc. The car ran fine however it did not idle. I was rewiring the the mafs plug to fit the 3 plug connector when two of the wires touched, i didn't disconnect the battery, so i got sparks. Well, maybe I was high of exhaust gas, but shortly after that I did it again. I get the wiring done and when I start the car up not only does still idle crappy but now it pours black smoke out of the back. God I am an idiot. Obviously it is running rich. Perhaps an injector is stuck open? Did I fry my ECU? If so could I have created a short in another place. If I buy another ECU and hook it up will it fry the new one? Lots of questions... Also I have a s13 blacktop in an s13. I did all of the work myself, that is probably the reason it is all messed up. Thanks for any help, or you can just make fun of me.
