Hello, I’m having issues with my infinti g35 sedan 2008 code U1000
Recovery
Car: ???
So I been testing everything but everything seems to be fine. When I bought the car the transmisión shifted rough and the vdc and slip light stay on I changed the tcm thinking it was the problem but no.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Your 4WAS system is in failsafe, there's an issue with the Front Control Unit (located next to the steering column). Check fuse #3 in the cabin fusebox. If that's good, you may have a bad Front 4WAS C/U.
