Allenhhp »
https://forums.nicoclub.com/allenhhp-u146359.html
Wed Oct 28, 2009 1:12 am
hello, am a new s13 owner. 92 KA 5pd 150k with minor timing chain rattling. I just got the car less than 2 months. I really wanna know how do you guys take care of the car?
How often should I change the motor oil, and what should I use? how is mobile 1 extended performance 10w-30 or 5w-30. I heard that 10w-30 will reduce the timing chain rattling. am thinking to change motor oil every 3k, is that too often?
How about gear box and differential fluid? how often and what should I use?I saw the post from SANIOLL said that mobile 1 75w-90 GL 5 for differential (am in north california, should I use 80w-90?)and redline 75w-90 GL 4 for gear box is good. what do you guys think of it and how often should I change both of the fluid?
is gear box fluid and differential fluid the same fluid uses in two places? or they are two different fluid? (the number looks the same and both are called gear oil, so.... same or different, am so confused....) Is the differential fluid and clutch fluid the same or they are two different fluids(or clutch=differential)? I heard that gearbox oil = transmission oil, is that right?
Thank you for reading my post, guys.I appreciate your helps, thanks.
