Any issues when putting it into reverse? That is if the clutch is not fully disengaging then it should affect every gear including reverse. Do you get any resistance when putting into gear while stopped, or taking it out of gear for that matter?SlickRed wrote:I'm new to the the G35. Just got a 2008 G35S and I love it. Does anyone know why shifting from 1 to 2 have a grinding sound. The dealership said it's normal but I refuse to believe that. I think there is something wrong the clutch or transmission. Any ideas
Was this a certified pre-owned car? If so I would be tempted to take it to another dealer and if it is a clutch it may still be covered under the classification of being a certified pre-owned car. While the warrenty itself is similar to that of a new car, the way I read this is they should have inspected the clutch and transmission prior to certification. By their statement that what you have is 'normal' indicates that they have not put any blame on to you in regard to a bad clutch or a defect in the transmission. To me this sounds like what you have now is then how it was when delivered, after all the dealer states it is 'normal'. There may be other recourse through the state as well depending on how it was represented at time of sale.SlickRed wrote:@ awdjdmtalon: Thanks for the reply. I have 26K miles on it so you probably are right. Don't know why the dealership will say it is ok then even though it is under warranty. I noticed that going from 2 to 3 and 3 to 4, the noise is minimized. Did you have yours replaced by the dealer and what was your strategy?
What I am stating is if the car was a certified pre-owned car and they state now that the car is acting normally then you have a statement that could be construed to mean that it arrived to you in this condition since the clutch is one of the items checked for certification.awdjdmtalon wrote:pfarmer. The dealer Infiniti dealer I got it from has free engine, transmission, clutches for life. The down side is. They are 5 hours from where I live. And in the next state. The next closest dealer is 2.5 hrs away. I called them and was told that a clutch is a wear item (which I knew) and that they could do nothing for me.
I did a lot of searching ebay and other places and found a clutch/lightweight flywheel for 600.00.
