Hi everyone,
New to forum, from Istanbul, TR.
Just bought a '97 Pathfinder SE Auto transmission VG33 engine 135.000 miles on it. LPG fitted on it. No oil consumption. Rear diff is whining after 60 mph.
While I bought it there were so many problems on it, then what I did to truck;
-there were so many cracks and leaks on the manifold and whole exhaust pipe system. Completely changed the manifolds and ehxaust pipes, mufflers. Turkish producer, aftermarket.
-changed all the belts, timing and other A/C, steering etc. belts with Continental, water pump, coolant...
-changed all the LPG hoses
-all brake pads
-steering power hydraulic hose was leaking badly, changed it also steering hydraulic.
-oil, oil filter, air filter
-all the plugs, NGK
-the bearing in the distributor was damaged and it was causing stalling&hesitating changed it now runs good but I think I need a new distributor
-brand new radiator, stock one was in very bad condition, aftermarket Turkish product.
-all the shocks and helezons and some several small parts in the suspension system
Now runs and pulls good but the distributor is not reliable. Also any ideas I mean which part to change to cut rear diff whining will be welcomed. Also any seller who can post a distributor to TR will be welcomed.
Best regards.
