94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon May 08, 2006 5:27 am
Sorry for the huge pic, but I thought this would help. Take out the assembly and put a metal piece just like what I did in the picture. Make a template with a coke can and cut it. I used small garden shovel from a dollar store and it was thick enough to cut, bend and function right after the installation. If the metal is too thin, it won't work. If it's too thick, you won't be able to cut it with sheet metal cutter. You might have broken other 2 plastic pieces that goes inside of the rails. If there's just a crack, you can use glue gun to fill the middle to reinforce it. If it's completely broken, you have to get a thick plastic piece and fabricate it. I used snow scraper(thick and durable plastic) and soldering iron, dremel and sand paper to fabricate it and it worked just fine. I wish I had some pics of those. If you don't take care of those other 2 rail guides, what's going to happen is... Window will move back and forth although it's all the way up. If they are half broken, it'll still work though. To check this, roll your window up 2/3~3/4 and try to move it back and forth. If it moves, you have broken rail pieces.
Hardest part is putting the assembly back in. If you don't do it right, you will have a leak, wind noice, interior door trim(seat belt portion) hitting rubber seal on the window, window not going all the way down, weather stripping getting messed up...etc. Be patient and you'll eventually figure it out. Somehow you find the brand new part, but if you don't adjust the assembly right, that plastic piece will snap again soon because that plastic piece can't take the tension from the arm. I was able to find a new part back in 2001 and a professional guy replaced it, but guess what it broke again because he didn't do a good job. I did it myself second time and it's been working just fine. When the other side broke 3rd time, the part was no longer available. Even though new part is strong and flexible enough to take the tesion, as time goes by, it'll age and won't be able to take it anymore. Anyway, please ask me if any of you guys have trouble fixing it. I'll try my best help you guys. I had enough on this issue. BTW, I checked out quarter window system of S13 Silvia, Infiniti vert even old Cabalier vert because size of quarter window looked same and they also have same front seat belt system, but all of them were different and our 240sx vert has the worst design and mechanism. Emailed Nissan and ASC, no response. Thought about custom making by plastic molding company, but price was ridiculous. Searched every junkyard in the U.S. & Canada, but everyone had assembly with broken plastic piece. Nissan or ASC should have reinforced the part with metal or at least made easy to replce just the plastic part. Well, it's another example of poor engineering....
Modified by 94_240sx at 11:03 AM 5/8/2006
