I have been reading the forum for about a month and already got some stuff done in my recently aquired 85 720 4x4, most of it by following advice I found here. I'm a somewhat proficient mechanic and have no trouble following instructions, but I'm new to Datsuns, been a GM guy my whole life.
My truck has a problem going uphill, or otherwise under torque, it starts to stutter as if starving for gas, when I let go of the pedal it idles normal and comes back, but it does take quite a cough and fart to finish long climbs.
I have done the vaccum delete thing, no emissions to be concerned about where I live and the vaccum system was a total mess anyway, I thought if that did not fix the truck's problem I could rebuild the whole maze of hoses from scratch following Fastboatman's post.
I have replaced spark plugs, wires, cap and rotor, set timing, adjusted idle and mixture in the carb. The problem persists.
I have NOT:
-changed fuel filters, fuel pump.
-double checked spark plug wiring. I found a diagram that supposedly is for my engine, but it doesn't match the way it's wired at this time, I wanted to share with you guys and double check if it is indeed the right diagram, or maybe one of you could point me to it. Here's the one I found, does not match the order on my truck
Any help will be greatly appreciated, I will do my best to help others with whatever I learn on my rig. I like it already and I'm a stubborn SOAB, the truck will stay with me and I will fix it. Period.
