HELLLPPP MEEE
bigbank_A
Car: 2008 Nissan Rogue
Leo2005
Try to unplug emergency light switch and see if it resolve the problem. If not then unplug/disconnect the radio. Something is giving electric short. Did u buy the car used?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
you problem is that you are listening to power105.1 lolololololololol even your car doesnt wanna hear eminem & rhiyanna for the 1,000th time LOL
your fuse box is either shorted out somehow, or its fried. its the one on the left side of your dash
zengshengliu
Car: 2008 Nissan Rogue SL
Did you change the light to LED? Some led cause the radio to dim because it "thought" you have the side marker on (meaning current through the side marker wire)
bigbank_A
zengshengliu wrote:Did you change the light to LED? Some led cause the radio to dim because it "thought" you have the side marker on (meaning current through the side marker wire)
I changed both rear signals both front signals
rear brake lights except the third
And have hid headlights i dont think they hurt anything
zengshengliu
Actually it does, the radio dim when it detect a current in the running light, and if the light is poor quality (or wrong type, as I remember the rear turn signal require a special base) will cause the problem. I have a similar problem where the brake light (which share the same light bulb with the side marker) cause the radio to dimmed. But since yours is the turn signal, I have a feeling its the front light
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
You may not think it can hurt anything, but it can if you don't use the correct type of bulb. If you're not using the newest Error Free LED bulbs with built-in CAN bus controller, it will cause problems with your system. As the saying goes, good LED bulbs aren't cheap, and cheap LED aren't good. Try putting back ALL of the bulbs you replaced.
Leo2005
I never experienced any problems with led bulbs in '08 but I was paying for them tremendous money in my opinion. As for my case I had a problem with radio in my '14 Rogue about 3 months ago but now I had a chance to record the problem with the unit:
Return to “Rogue Forum”
