+25 in the rear? that doesnt sound rite at all... im telling you +33 should do it for the rear.... or even somewhere in the low 30's, going into the 20's doesnt seem logical....im guessing the max drop on those is somewhere around 2 1/2- 2 3/4 somewhere around there....blindsnyper wrote:+38 with a 5mm spacer on a 7" wide wheel wont get you close in the rear, but will for the front. for the rear i would guess an 8" wide wheel with +25 to 30 would get you there. and probably a 185 wide tire in the front and a 195 in the rear for the stretch.
tien coilovers are less of a drop than the tanabe coilovers.
i have +38 wheels with a 5mm spacer in the rear on a 7 wide wheel and it still needs about 5-8mm the be flush, but to get them as flush the pic posted aboveanother 5mm or so would be needed.superskunk wrote:
Without having a car to measure I'd guess it would need to be around +35.goteejgo wrote:I'm goin for an 8.5 wide whel in the rear and I'd like to do that on all 4 corners. Any suggestions on offset for that?
hmm... i may thinking of my 20's, they are 7 1/2 and a plus 38 offset....blindsnyper wrote:
you dont know anyone with any 4x114.3 rims in low offsets? i would just test fit from there if at all possible...goteejgo wrote:I'm goin for an 8.5 wide whel in the rear and I'd like to do that on all 4 corners. Any suggestions on offset for that?
