2001 Infiniti QX4. Installing Hella 500 lights.
The Hella instructions state to connect fog lights to the low beams 12v source.
Hella PDF here: http://www.myhellalights.com/files/8312 ... ctions.pdf
I will be using the switch.
So, I have a test light. However, had some trouble figuring out which wiring harness connects to the low beams. I understand that the middle wire will be the low beams 12v, black will be the ground, and the other wire will be high beams.
However, there are many harnesses plugged into my lights. Is it the middle harness directly next to the twist off plastic cap (the ones used to replace headlight bulbs)? It has black, orange, and brown wires coming out of it.
Also, if anyone has a link for a good write up that would be great!
Thanks.
