Helix tubular turbo manifold ?
Jesse SR20
Car: 1990 S13 fastback
Anyone used one, seen one, heard about one ? At only $310, I just have to question it's quality.
It's at Touge Factory.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
You can get that same manifold on ebay for like 150. It is the same thing that has been going around since the magazines knew about SR20's.
msaskin
Car: cars, computers, skiing, mountain biking
Looks strikingly similar to the ssautochrome manifold, with some extra welds, and at twice the price :)
For $150 get the autochrome one on ebay. the way i see it, all stainless manifolds, even the $900+ jic ones, are prone to cracking. if the $150 one cracks, i'll pull it off the car and weld it back up :)
~matt
Jesse SR20
msaskin wrote: the way i see it, all stainless manifolds, even the $900+ jic ones, are prone to cracking.
That seems like a bad conclusion to jump to.
Stainless is a outstanding material to use for manifolds. But certain design features must be used to account for stainless' large amount of thermal expansion. For example, using a segmented exhaust port flange. (neither the helix or ssautochrome manifold use this feature)
Take a look at http://www.full-race.com. They've be making tubular stainless manifolds for turbo hondas for some time now. And the honda crowd loves em. And they make manifolds for nissans aswell. (but veeeery expensive)
msaskin
Jesse SR20 wrote:That seems like a bad conclusion to jump to.
Makes sense. All the stainless manifolds i've seen crack (mainly the OBX and the old style SSautochrome ones) actually just broke in the middle of the cylinder runners, so it's not in a terribly high stress area.
I've been attributing this mostly due to the thin wall design of the older style manifolds, and the weight that they must (somewhat) support.
Hopefully the newer style autochrome ones are better. The one I put on seemed pretty beefy compared to the OBX one my friend bought.
As a side note, I wish I could afford a full-race manifold...those things are trick :)
~matt
Jesse SR20
msaskin wrote:Hopefully the newer style autochrome ones are better. The one I put on seemed pretty beefy compared to the OBX one my friend bought.
How long have you been running your current SSA manifold ? What type of boost level/hp ?
Have you run other SSA manifolds in the past ? Problems ?
If the new design proves to hold out for a reasonable amout of time, then it's a great alternative to the high end manifolds.
Lemme know, thanks.
VitaminT
Car: 93 240sx SE
Yeah I don't think the manifolds crack where the flange is, but rather when all the pipes come together.
msaskin
Jesse SR20 wrote:How long have you been running your current SSA manifold ? What type of boost level/hp ?
Lemme know, thanks.
Just a few weeks for me. I run 10-11 psi on the street and at the track. I'll be hitting a number of open track events in the coming months in 110+ degree heat outside, so a bunch of 30 minute lapping sessions in that heat should show any flaws real quick ;)
~matt
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
Full-Race makes awsome stuff. I plan on having that SR mani some day... some day...
VitaminT
Car: 93 240sx SE
I just wish they made a T25 bottom mount manifold. Maybe even with an external gate flange.
