Helical LSD
dcdrifter
Does anyone know if a Silvia S15 Spec R helical LSD will bolt up to an S14?
veilsideS14
Yes, it will. The speed sensor on the front of the diff makes it longer much like the ABS sensor does on an S14 VLSD. Other than that, it's the same.
dcdrifter
My car does not have abs. Does that make a difference? Will I need anything else to get this to work. I have a 96 240sx base model.
veilsideS14
Some say that you can sqeeze the diff in there with the longer base model driveshaft but your best bet would be to get the driveshaft off of an SE or the S15 you got the diff from.
dan240
Car: killing stealth R/T and camaros
Night, i got a question for you. You stated that you sell the LSD from an R33 for 600 usd (or something around that price) and i'm wondering if it is the rear diff with the 4.3 gear?
Carson
