Heli Coil Size for a Ka24e Sprocket?
1997D21
Car: 1995 nissan d21
1997 nissan d21
Hi ,
I just stripped the sprocket bolt in my 95 nissan pickup and was wondering if anyone could tell me the size helicoil kit i
should use and what size bolt i should put in after installing the kit?
thanks :sad:
seang
Car: Ford Fiesta ST
What sprocket? Also, I think heli-coils return the threads to the original size (and original bolt size).
1997D21
1997 nissan d21
It's the upper timing chain sprocket and the bolt is 24mm
Q451990
If the threads aren't fubared too badly, I would try retapping them with a tap and dye set before you resort to installing a heli coil. Might use some break-able locktite to be safe when you're done either way.
Heath
