3Q Jay wrote:you should have a bleeder like a brake caliper bleeder at each actuator. on the (H)G50, they are easy to get to at the top of the 'strut' tower. same principle, but you don't have to have an assistant pump the pedal
Ok, I can see the bleeder, How would I go about bleeding this?? Jack the car up attach a peice of hose the the nipple, Undo the nipple and slowly lower the car until air stops coming out? Should I do this like brakes and Do each corner starting with furtherest away from the fluid filler tank? Also - Is there another fluid I can use instead of the Nissan ACTSUS fluid? As here it costs over 120 NZD per litre. Which is about 60USD per liltre.
Q45tech wrote:If the Nitrogen pressure in each accumulator [attached to shocks] and tank valves is LOWER than ~~ 900 psi the ride will be hard and jarring regardless of height.
The compressed Nitrogen is the shock absorber for a narrow range [+-0.5"] of motion vs hydo fluid pressure for the +- 3" range.
This seems like the problem , It is extremely bouncy almost like it has "cut" springs. Would bleeding this sort it out? Thanks heaps.
also can someone tell me if I turned the rear height adjuster a full revolution on the sensor then set it, is this going to put the difference between the two rear sensors off?
thanks.
