Open the hood and right above the headlight on the metal cross frame there's a oval shaped hole (That's what she said :lol: ) You'll need a flash light and a long phillips screw driver. Shine the light down in the hole and you'll see a white round circle with a "+" or X depending how you look at it. That is the adjusting knob. Here's the pornographic part:
Stick the long phillips screwdriver down in the hole and into the X part. SLIGHTLY put pressure on it and turn the adjusting knob. Right will raise the reflecting bowl. left will lower it. BE CAREFUL as the adjusting knob is made out of plastic.
You don't want to strip it out. Now Go Fight WIN!
