s13EastTN »
https://forums.nicoclub.com/s13easttn-u15057.html
Wed Jul 21, 2004 4:17 pm
Ya, I beleive that is a problem w/ how the manual is setup to start compared to an automatic. For instance, and automatic can't start in gear, to it checks to see if it is in park or neutral. A manual can, however, start in gear so it checks to see if the clutch is pressed down. I beleive the little "check what gear your in"sensor needs to be wired up like xatracing said. I beleive you pull the console out with the shifter and loop it like he said.
