willmoodom »
https://forums.nicoclub.com/willmoodom-u155679.html
Fri Nov 18, 2011 4:50 pm
thanks for the replies. BCC93QT, i don't believe its a hose. i did redo everything, but that would cause a continuous smell not to mention a serious fire hazard as much as i get on it. but for the sake of my sanity, ill check it.
Mint Q45A, i was a little confused by the thread you sent me and your response to this. you replied with a possible leaky injector or o-ring, but your thread proved no internal leaks. however, i don't understand how knock sensors could cause flooding situation.
im drawn to the coolant temp sensor being bad.once up to operating temp all is well and no matter how cold it is, the Q starts on a dime. but again, for the sake of sanity, ill do a pressure check. my injectors and rail were cleaned and installed by Mr. Injector. all i had to do was bolt it down and plug it up. what all can cause over fueling on cold start? coolant temp sensor, o2 sensor, tps? another thing i noticed is it takes my car forever to warm up according to the gauge. idle 10 minutes and some driving and it just creeps. anyone experience this? possible connection? ill be pulling entire interior soon (swap tan to grey) and will go through all wires and connections. electrical gremlins! though people advised me to get rid of my baby for 94-96, i cant do it.
