DRIFTINIZ wrote:car runs strong and idles good....got all the essential upgrades for the sr swap (i.e. walbro pump and 300zx fuel filter).....got the boost up to 10 psi which is conservative...still no where near max w/the factory 370cc injectors and the t25 turbo
boosts all the way until i hit about 5500 in any gear i choose....then the car won't rev any more than that.....lunges forward and i have to let off the gas.....kinda feels like a fuel cut b/c the car bogs big time
done some research......is a bad tps maybe at fault???.......maybe injectors....maf???.....blown turbo????......car still spools and pulls hella like it should LOL
please any help would be appreciated!!!
I have the EXACT same problem, except that my car only bogs at 5500, any rpm lower or higher than that, it runs perfectly fine. It is at a so specific rpm to the point that i wouldnt realize the problem when reving it up on a straight line, however, when I go driving in autocross or the canyon, I need to stay on the throttle holding at a specific RPM through long curves, I then realize the engine jerks in between the range of 5300 and 5700, and I tried to hold the rev at 5300, 5400, 5500, 5600..etc one at a time on the straight line to diagnose the problem, and I realize that the "fuel cut" feeling only happens at 5500. I am positive that it has something to do with the MAF sensor because at 5500, my AEM wideband gauge reads 10.0 A/F ratio, which tells me that i m running very rich compared to other rpm ON BOOST(usually 11.0), therefore, I took out the MAF sensor and cleaned it with MAF cleaner, then I tried it again, the engine doesnt bog anymore on first gear, and it feels much better on second gear too, ofcourse i m refering to at 5500rpm. Inductively thinking, I believe it is a bad MAF, and I m going to get a new MAF sensor for SR20det to see if it will truly solve the problem. Hope this will help, but try to change the MAF sensor assembly, I m pretty sure it is the root of the problem.
