Ryan_2.4litereater »
https://forums.nicoclub.com/ryan-2-4litereater-u108000.html
Fri Oct 10, 2008 6:46 am
oh yeah yeah, i know why i dont have any heat (cause of the heater core.) i already knew that. i plan on getting that fixed. but that doesnt fix my blowing problem. so your sayin it could be the blower? how do you figure out if any of those things are gettin power(heat unit)? i was gonna try runing a different wire to see if the problem was just a bad switch. but if its the blower(which by the way,i have no idea were that is) i dnt wanna spend 50 bucks on a unit for no reason
if it helps any. before it COMPLETELY went out. i was able to knock on the dash and floor board a couple times then it would work. bout 5 min. later i relized nothing was coming out. it did that a few times then it would never turn back on since..
