elwesso wrote:Do the segment check on the climate controller... Self diagnosis...
Otherwise check the thermostat... What does it do when you jack the heat all the way up to 85...? Remember it is a climate controlled device, so once it gets warm it will cool the air so it doesnt get too hot.
I performed the Self-Diagnosis Test and the only thing that the 2 things I saw that were not right were:
a) The Fluorescent display tube did not light up when I did: STEP 1: Checks L.E.D.s and segments. That is the little dot shown in the illustration on Page HA-68 My display can be irratic at times where the digits start racing in high-speed continuous loop and the display can even go completely blank at times even though all the functions still work as usual.
Here is a picture of the display. Note the temperature:
b) After performing STEP 2: Checks each sensor circuit for open or short circuitfrom Page HA-69, I got a Code No. 25 - Sunload sensor.This test was performed during the day, but not in direct sunlight. So I don't know if it's faulty or if the conditions were not optimum for the test.
I haven't checked my thermostat, but the radiator was replaced by the previous owner.
The heat comes on, but the car is not warm enough even at 85 and full blast.
