FSM said remove the bolt, fill the coolant up to the radiator neck and close the bolt and cap that's what I did... I must have done something wrong...sleepyeyes87 wrote:There should be a 10mm bolt on top of your intake manifold with a sticker taht says, "never open while hot" It's a bleeder for the coolant system.
Thanks for the info. I still have some air in the system, so I'll do that...biggie wrote:KAs are the worst for getting air bubbles. The best thing to do (on top of bleeding with the screw) is to sit the front up on jack stands or use a funnel on top of the radiator(and fill it up where coolant is sitting in the funnel). This will get the air to go to the highest point. Also use a pumping action on the top rad hose to work out bubbles.
According to FSM, you need 6.7liter(1.77gallon/7-1/8 US qt) with reservior tank. How much did you put? You need good amount of coolant to keep your engine cool. If you have too much air in the system, coolant won't circulate enough.Alastaplat wrote:what if it isn't air bubbles that I have in my system? could it be anything else.... I'm just trying to get rid of this problem cause I just spent a lot for a reconditioned motor because of that problem. that would really suck if that happened again, you know
I replaced thermostat with OEM unit recently. I didn't go for Nismo thermostat which opens up at 149F. I was wondering what's the benefit on that, and if Nismo thermostat is better, why Nissan made OEM one opens up at 170F. Just curious...biggie wrote:I'd basically recommend changing the thermo everytime the coolant is drained. They tend to stick after a coolant change for some reason.
The lower temp if just for high temp areas, it'll help keep it a little cooler. Also for racing you would want it to open a little sooner. Autozone/Advance have some that will open around 150/160 and they are a ton cheaper than Nismo.94_240sx wrote:
Oh. okay. I'll try low temp one next time then...biggie wrote:The lower temp if just for high temp areas, it'll help keep it a little cooler. Also for racing you would want it to open a little sooner. Autozone/Advance have some that will open around 150/160 and they are a ton cheaper than Nismo.
BTW, to check your thermostat, start the engine and keep checking your lower radiator hose. If it stays cool too long, it means thermostat got stuck, so water can't circulate... Once thermostat opens up, you will feel it gets hot fast.Alastaplat wrote:water pump was replaced right before I got it, you can tell it's brand new. and the thermostat.... God know?? but I did go out and get one today, I just got to figure out how it put it in, I'm not a big mechanic lol
