nuQ »
https://forums.nicoclub.com/nuq-u4532.html
Fri Dec 30, 2005 1:57 pm
I usually always go outside and warm up the Q before driving. The other night I went out to start the car to set up my Sirius. I noticed I heard some "gurgling" through the dashboard, like the coolent going through hoses. Well, when I went back out the temp. gauge showed a normal oper. temp but only cold air blowing through the vents. What's weird is that I seem to get "warm" air when I push the defrost button. The other night I drove around the block and got slightly warmer air through the dash vents, but not much. Tonight it was only with defrost pressed. Don't know if this has any baring, but most times the display on my HVAC unit doesn't light up, but the button functions all work. Because of this I cant run the codes!!! I just got a used HVAC off ebay. Any ideas?? Thanks
