of course i did #1 obviously..lol but ill have a look at the other twoAce2cool wrote:#1. Is the car warmed up? (I know it's obvious but still)#2. The trim piece on the T-bar that has the map lights on it. Take that off and see if the little fan up there is spinning#3. Heater core...
All i can think of.
I could never figure out how to use that friggin thing....Zwicked wrote:Could also be the motor that operated the mode door that directs the air through the heater core or not.
Have you tried running diagnostics? I assume you have the climate control
http://www.ttzd.com/tech/autocctech.html
Most likely, heater core. Had this issue with my previous Z, having it again with my new Z.. tons of fun. Never replaced them though I will with this one. Entire dash must come out, supposedly a 10-15 hour job.ziptek wrote:So what should i check for this?? i turn it on but just blows out cold air, help plz..
You can use this guide: http://twinturbo.net/net/viewm...01202 if you don't want to tear the dash down. I haven't used it yet but a friend of mine said it was easier (in some ways) to use this method. If you'd like to tear the dash down however you can use this guide: http://www.twinturbo.net/net/v...68248 I haven't decided which route I'm gonna go yet..ziptek wrote:So what should i check for this?? i turn it on but just blows out cold air, help plz..
