tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Mon Nov 23, 2009 1:16 pm
that only happens with air bubble in the system
burp it. when you stop driving the car and its hot there is a bleeder valve on the passenger side at the back of the engine by the battery cover. Phillips head #4 I believe.
Open it slowly. You'll hear the hissing of air leak out. When the air stops coming and its just coolant close it quickly.
Dont open it fast or completely remove it. The coolant is hot and can burn you if you do.
