cocheeze »
https://forums.nicoclub.com/cocheeze-u34901.html
Tue Dec 20, 2005 5:16 pm
that is almost exactly the same problem I am having with my '82 stanza. ..
Do you hear the sound of water gurgling under the dash when you hit the gas after the car has been idling for a moment?
I don't know if our cars have similar heating systems, considering mine is 20 years older than yours, but I am pretty sure that my problem is a obstruction between the heater core and engine block, and the only time water gets past enough to heat the air blowing through the heater core is when I hit the gas, and thus speed up the water pump and increase the cooling system pressure.
Maybe that's your problem?
