Heater is not blowing hot enough air for a hot engine
Speed Monster
Car: 1994 240SX 2.4L Convertible
I have a '94 vert SE. I have a heater problem. My heater is not blowing very hot at all when the engine is hot and running. I know the heater core is good and the coolant was just changed today.
Do you think I may have a heater valve not working properly? If so, where the heack is the heater valve? And, is it repairable or do I have to replace it?
I could really use some suggestions, thanksSpeed Monster
Eikon
Car: 71 240z, 93 Supra TT
It could also be your water pump.
The heater works by circulating the hot coolant from the engine through a radiator, then forcing air through that radiator... the air forced through then heats up prior to entering the cabin.
If your water pump is weak and not circulating the coolant very well then your heat would be weak as well.
Just another idea.
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
First take a look at the thermostat; it's quick and cheap.
94_240sx
Car: 94_240SX
cmkelly wrote:First take a look at the thermostat; it's quick and cheap.
Touch upper and lower radiator hose when engine is hot and see if both hoses are hot. If not, thermostat is not opening up.
Speed Monster
Guys, Guys, Guys,...I've done that.The upper and lower radiator hoses are very hot, and the water in the radiator is very hot coming out the Pet c*** so that means the Thermostate is open and working.
The water pump is good because I can see the water flowing fast in the radiator when I'm looking into the spout and reving the engine + their is no water leaking from the weep hole on bottom of water pump (sign of a bad seal in water the pump)
This one has me kinda frustrated!
le_ryan
Car: Mazda3
91 Nissan 240SX SR
one possible reason is "
you know when you turn the AC from red to blue (hot to cold) well that knob has a cable that pulls open a flap when you turn it to cold, allowing air from outside in, when you turn it to red (hot), it closes that flap and only allows air from the heater core, you door may be slightly open.
the door is located in your center council, directly behind your radio,
le_ryan
Car: Mazda3
91 Nissan 240SX SR
let me know if you need any other help about it, i already did mine
Speed Monster
Now you're talkin" this it the kinda idea i needed.
Okay, sooooo, take out the radio? then exacly where is it and how to get at it?
le_ryan
Car: Mazda3
91 Nissan 240SX SR
well its located in a box, i think they are 8MM screws in it (silver ones) hang on i gotta go look at my car again to make sure how this works again
le_ryan
Car: Mazda3
91 Nissan 240SX SR
ok, if you pull your radio out and look under the AC, you can see a small clear tube that has a cable in it.move the knob from red to blue and youll see what im talkin about, the problem could be anything from the tub hanging loose, not allowing proper tension in the cable, or something along that line.
follow the cable to see where the box is, IIRC you have to take the glove box off and remove the boxes that lead to it to expose the "hot cold chamber" <-- not the actual name ..
le_ryan
Car: Mazda3
91 Nissan 240SX SR
after you get to the chamber, move you knob from red to blue and check to see if the door opens all the way, and closes all the way, if not, theres your problem, if it does ... well then at least you know it wasnt that ..
Speed Monster
Sounds easy enough.
I'll give a try tonight. THANKS! for the idea, you may have saved me some bucks. I'll let you know how it turns out.
SM
94_240sx
Car: 94_240SX
Speed Monster wrote:Sounds easy enough.
SM
If you need climate control unit, let me know. I have one for sale. Good luck!!
Speed Monster
Ok, that's good to know. I'll let you know
