mello88 wrote:I don't think it should matter on the heater hoses but I'll let someone else confirm that
For your fuel hoses:• fuel pump hardline to filter• filter to back of rail (DO NOT HOOK TO FPR)• out the FPR to tank return hardline
FPR works by restricting the return of fuel to the tank. If you hook up your hoses wrong, the FPR will restrict flow into the rail and you probably won't get your engine to start.
perfect answer for the second question. thank you
one more question. the hardlines which are connected to the fuel rail by hoses are laying on top of my greddy intake manifold. can i delete those and just run hoses from the fuel rail and route those under the intake manifold straight to the fuel filter and return line?
