heater hose routing
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
which goes where?
I was almost sure 2 goes to 3 and 1 goes to 4... but just in case.
this is a series 1 25 with greddy intake mani
R32ONP
Car: R32 Skyline GTS-T
RB20DET
it wouldnt effect it either way u put them on as they are both just inlets straight into the heater core...make sure u bleed it probly with the heater ON full
hungryjoseph
Isntthere a directional valve in the core
R32ONP
RB20DET
not that i know of but unless someone knows for sure??? can u blow through it both ways?
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
either way is fine........
240AceX
Car: 98 240SX SE
For easier pipe routing and to have the pipes spaced out, I went 2 to 3 and 1 to 4 on my swap. As you will find out by trial and error if you go 1 to 3 and 2 to 4 the heater hoses will be crossed and hitting each other.
hungryjoseph
thank you for your inputs
Joe
hungryjoseph wrote:Isntthere a directional valve in the core
but there isnt one in the engine :p
it doesnt matter which ones go where. the "valve" in the heater core is just to allow coolant to flow into it so it will work.
hungryjoseph
ahhh that is true. i gues either way without the heater on the core still has coolant going through it
