Heater Hose Help with swap
mugenrsx
i did search and found that one with the picture but i still am confused , i have three hoses the L, The U shape, and the S shape i am just wondering where they all go and do they all connect to the firewall of the car? anything helps cause my instructions says you connect the L and the U so that made it more confusin
Rican_Nick
pretty much what ya wanna end up with. the hoses will connect to the plastic "tubes" in the firewall that go to your heater core.
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Since the jdm hoses have to reach the L side(usdm driver's side) of the vehicle, they are alot longer than needed to reach the usdm heater core connections. I used the jdm hoses, mocked them up by eyeball with the engine in the car, and cut them to fit. They fit perfectly...but I have a shop with 13 new hoists I can use whenever I want, which allowed me to do it comfortably from underneath the car.
CMG
Car: 1989 240sx Hatch w/ Redtop
mugenrsx wrote:i did search and found that one with the picture but i still am confused , i have three hoses the L, The U shape, and the S shape i am just wondering where they all go and do they all connect to the firewall of the car? anything helps cause my instructions says you connect the L and the U so that made it more confusin
You should have enough hoss that came with the engine to do it, just make sure you don't crimp it anywhere...and from my experience it doesn't matter which goes on top or bottom.
