My RB25 »
https://forums.nicoclub.com/my-rb25-u61932.html
Thu Aug 09, 2007 12:25 pm
Not sure if the older cars have it. But a lot of new cars have...I can't remember the name, but I change a ton of them in the winter on newer Nissans. It looks like a big circuit board, but it has it's own harness and connector. It controls the fan speeds. Usually all but one will blow out, but if it gets bad enough. I've seen some practically melted.
Are you at least getting power to the fan? With the car acc or on, turn the fan on and check the fuse with a test light or voltmeter. If your good, then go to the main harness to the blower motor. I haven't tore apart my dash yet, but some cars you have to to access it. Idk, I haven't really looked for it yet, but it could also be on the floor against the firewall, on top of the transbell. If you get this far, check the wires at the harness to see if you have power. If you do, replace your blower motor. Could save you money.
