SUB ZERO CAR FANATIC wrote:How do i check to see if thats whats wrong? I know when i press the mode button, all the different modes work, such as- feet, defrost,head,feet and defrost, etc, you can feel it blow out of the areas itssupposed to and you can hear the doors or whatever under the dasharea open and close. thanks for your input brian
Dont confuse air DIRECTION doors {defrost,face,feet,etc} with the heater control mix door which directs air through the heater core before it reaches the air DIRECTION doors.Sounds like your heater control mix door is stuck closed, and air is never traveling thru heater core before it reaches the vents{common on 94-96q as the door position lever is plastic and breaks quite easily}
Search for posts on repair---it involves alot of dash assembly to get to it.Someone on here has posted a fix with pictures accessing it by removing the radio and climate control display and getting to it that way.
