Welcome to the forums, mesaman!
mesaman wrote:My first thought is that the thermostat is stuck open, but even when the car is registering normal operating temperature, wouldn't there be some warm air coming out.
Correct - If the engine temperature gauge is in the middle of the scale, the coolant should be hot enough to produce plenty of heat inside the vehicle. So, it sounds like either your blower isn't working, or the air isn't being directed where it should.
If you push the blower speed switch up to its highest setting, can you hear the blower running?
If you push the AUTO button, turn the temperature knob up as high as it will go, and then push the dashboard vent button, does hot air come out of the dashboard vents?
