86 720 »
https://forums.nicoclub.com/86-720-u144276.html
Fri Jan 25, 2013 8:35 pm
take a picture of the hoses to make sure everyone is on the same level.
One of the hoses should make an immediate turn and connect to the rear of the engine block. The other hose should connect to the water outlet neck near the water pump.
If these are hooked up, and your truck runs normally, chances are your heater core is clogged and needs to be replaced.
